My homeflame super does not seem to have the same level of flame on 4 setting as it did last year logs use to get reddish after being on for a while and now it doesnt
  • Heating & Co... Master
  • 3,484 Answers
Its is possible it my need cleaning / service burner .
Posted on Nov 05, 2016
6ya staff
SOURCE:
I have an Empire RH-65B-6 Natural Gas heater. It is 4 years old, and the flame is quite high.. enough to where it chars the ceramic log on one end and leaves "soot" on the viewing windor. What shoul
I'M GEUSSING THE FLAME IS QUITE YELLOW IN COLOR CORRECT? IF SO THE AIR SHUTTER WILL NEED ADJUSTMENT ON THE END OF YOU BURNER TUBE ASSEMBLY. HOPE THIS HELPS
Dec 27, 2012 | Empire Heating & Cooling
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Apr 21, 2011 | Whirlpool RBS305PDS Electric Single Oven
Initial problem was that fire was taking long time to light, no spark being generated intermittently. Now Gas fire seems to be going off on its own when it has been on for a while. Fire is the hole in the...
First, have you changed the battery in the ignition system? If you haven't this could be causing your ignition problem. In addition, the Thermocouple may need to be replaced to solve the problem of the burner flames going of on their own. That's assuming the pilot light is also going out when the burners go out. It would also be wise to check the vent pipe to make sure it's not obstructed in any way. As this also, could cause the flames to go out. Because there is a Safety Overload Switch, that automatically shuts the burner off is there is a gas and heat buildup/backup in the firebox.
As far as replacing the Thermocouple is concerned, this unit uses the same type of stand-alone Thermocouple, as the older DESA Vent-free gas log sets and fireplaces used. It's held in place with a saddle strap mounting and is fairly easy to replace.
These fireplaces are made in the UK and therefore, are more complicated to install, diagnose a problem and then solve it, than those made in the U.S.
Hope this has helped get you headed in the right direction.
Feb 25, 2011 | Heating & Cooling
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Bought valor homeflame super off a friend gas fitter won't fit until he gets istruction maual
google valor you should be able to get manual off there site you will need model number
May 02, 2010 | Heating & Cooling
Gas logs while turned on seem to fade, nearly go
you must keep the burner and the pilot light area clean and free of dust also,the area where your burner gets air most of the time it has an adjustment to give it more or less air.I have had my dyna glo vent free model for 8 years.A good cleaning in late fall with low pressure air and 1 or 2 times through the winter depending on conditions of use.
gatesmason88
Jan 07, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
Series 80 gas dryer. Turn on and flame only lasts few mins.
Intermittent contact inside one of the gas valve coils. Replace. Part number 279834.
You can order them at AP Wagner. Use coupon "New10" for 10% off
Oct 16, 2009 | Kenmore 75944 Gas Dryer
I can't get past level 8-8 (Nintendo DS, Mario Bros.)
Well if you have played the original Super Mario Bros. on NES, then you'll know that the last level has a certain secret path, only crossing which will let you advance further in the level. Same with NSMB, in the last level in the Bowser's castle, just because you encounter Bowser, there is a secret hidden path which you have to cross in the correct manner. When you do so, you hear a sound. Check this video out on how to exactly find the correct path:
Aug 06, 2009 | Nintendo New Super Mario Bros. for DS
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
