Apple iPad Mini Logo
Nicole Johnson Posted on Nov 06, 2016
How do I do a factory recovery on my mini ipad
Astolfo Schiavone
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 07, 2016
Astolfo Schiavone
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
137
Points
ITunes enables you to restore iPad mini to factory settings. Before you start restoring iPad to factory settings, please note that you need to install the latest version of iTunes on your Windows computer or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
1. Plug iPad into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPad at the upper right corner of iTunes, and then the information of your iPad will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPad. Then iTunes will start restoring your tablet to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore your device to factory settings, it will restart. Now you can set it up as new.
http://www.leawo.org/tutorial/how-to-restore-iphone-6-plus-to-factory-settings.html
Password screen frozen on iPad how do I reset
In your case, you can still try some methods to fix it. Just follow below steps.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
For more methods, check: How to Unlock iPad?
2answers
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Hot to factory rest an iPad mini with out you sing the apple I'd or password
You need to connect it to Itunes from a PC or MAC, enter it into recovery mode and Itunes will allow you to recover it
1helpful
Setting up gave wrong email will not let me fix it
Barry, You may have to do a factory reset and start over, or contact manufacturer for suggestion.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apple iPad mini Retina How to master reset
Perform factory reset Apple iPad mini 2 128 GB
How to Easily Master Format APPLE IPAD MINI 2 RETINA DISPLAY with Safety...
6answers
Lost all contacts on iPad mini
If the important contacts in iPad get deleted, you will try to get them back. Restoring iPad with the iTunes backup is the easiest way to recover deleted contacts on iPad mini. If you update your iPhone backups regularly, then you can recover most of the important data from the backup. The restoring process is also easy to be done, and the following tutorial is for the new users of iOS devices:
  1. Connect iPad mini to computer with USB cable, and iTunes will launch automatically. If not, you should manually start iTunes.
  2. iTunes will recognize iPhone and display the iPad icon at the upper left corner. Click the iPad icon.
  3. The control panel of iPhone appears after you click the iPad icon. Click Summary in the panel.
  4. Click Restore Backup in the right part of the window. Then iTunes will allow you to choose the iPad backup, and finish the restore.
Visit here to know more methods about iPad contact recovery.
http://www.leawo.org/tutorial/how-to-recover-deleted-contacts-on-iphone-6.html
How do I reformat my iPad Mini?
  1. Restore to Factory Settings Without iTunes. It is just as simple to restore your iPad Mini without iTunes. Go to Settings > General > Reset and tap on Erase All Content and Settings. ...
  2. Restore Factory Settings With iTunes. Start by connecting your iPad Mini to your desktop computer with the provided cable. Start iTunes.
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
How to unlock ipad 3
As for unlocking iPad, there are several ways you can resort to. Just follow one of them as below shows.
iPad Air
iPad mini/iPad pro
How do i restore my password disabled ipad?
You can enter the recovery mode in iTunes and restore password on your disabled iPad. Just follow below steps to do that.
iPad Air
iPad mini/iPad pro
restoring-ipad-software-2ka233npl0212ndjbhnpio3z-3-0.png For more methods, check: How to Unlock iPad?
How to unlock ipad if I forgot password
If you forgot iPad password, there still are several methods to unlock iPad. Here take one of them as an instance.
iPad Air
iPad mini/iPad pro
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
