SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
SOURCE: I have a printer ?HP c7280 All-in-one?a message,
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
SOURCE: HP Photosmart C6180 All- In- One Printer "ink system failure"
hELLO PLEASE TRY
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: ink system failure, how do I reset the printer
The ink system failure is caused by air in the ink feed tubes. This happens if you allow the ink to fully run out of the cartridge and it **** air in or if you use poorly filled refill cartridges that have air bubbles. To clear the error you will need to perform a purge on the ink lines to clear the air out. We have a step by step guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The process will take about 10 minutes to finish but then you should have a fully functional printer again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
