Trying to find lint trap in GW11 model
SOURCE: lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
SOURCE: need to know how to clean lint trap and where is
The only trap on a Kenmore Elite HE3 is in the drain pump. The following link explains how to access and clean it out:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provided and let me know if you have any questions. I personally own one of these washers and have repaired them many times. If you are experiencing drain problems, the problem will most commonly be attributed to the drain pump trap becoming clogged with debris. There's usually an error code associated with this problem of "F02". If you attempt to clean the drain pump and you discover the pump to be clear, check the drain lines (especially the line running from the bottom of the wash tub to the inlet side of the pump). If all these preliminary checks don't solve the problem, the manufacturer recommends replacing the drain pump.
If this is not what you were talking about, please post back and elaborate a bit more so I can understand the problem you are having. I hope this helps you.
SOURCE: Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
