SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
SOURCE: why does my washing machine trip the electric
Someone with a wattmeter needs to read the wattage load by the machine when washing. If the running load is greater than the rated load of the machine, then the problem is likely the motor itself or the drum bearings are going bad. If the electrical load is normal, then the breaker in the house electrical panel is either under-rated, or the breaker is defective. If the breaker is a 'ground fault' type, the washer may have current leakage to ground causing the breaker to trip. Another possibility is that there is another outlet that is on the same circuit and the combined load trips the breaker. Shut the breaker off and try any other sockets in the area to see if they went dead too. Hope this helps!
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
SOURCE: hoover oph 714d optima 7kg
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
