There actually IS a fuse/buss of sorts, if you really stretch the definition, anyways...so if your switch checked out good, and your outlet didn't fizzle out and blow a house fuse or trip a breaker, in the machine base, near the motor, there is a "Thermtrol". Its purpose is to prevent overheating, so if your machine got hot, then stopped and would not start again...the manuals and experts recommend unplugging the machine, letting it cool for a half hour or so, then clear any possible blockages, and try again...If you're still not getting any power, check your wiring from wall outlet to machine...then from base to switch..If your wiring is all good, connections tight and right, you might have a faulty/failed thermal regulator.
You're not alone : http://www.epinions.com/review/hmgd-Large_Appliances-All-Vacuum_Cleaners-Hoover_WindTunnel_Upright_Bagless_Vacuum_U5755_900/content_78274858628?sb=1 If you can get Hoover or a repair shop to provide you with a replacement, the procedure to replace is pretty straightforward...a few snips and crimp or two, and you'll be as good as new... I know this question posting isn't brand new, but I still wanted to provide help for something that can be crazy making for a consumer who just wants to pick up the fuzzies and be done with it and needs to find a way to motivate their appliance to run. Hope this helps someone :-)
You're not alone : http://www.epinions.com/review/hmgd-Larg... If you can get Hoover or a repair shop to provide you with a replacement, the procedure to replace is pretty straightforward...a few snips and crimp or two, and you'll be as good as new... I know this question posting isn't brand new, but I still wanted to provide help for something that can be crazy making for a consumer who just wants to pick up the fuzzies and be done with it and needs to find a way to motivate their appliance to run. Hope this helps someone :-)
Hoover U5720 900 WindTunnel Upright Cleaner Consumer Reviews Thermal...
RIght on my friend. After pulling the motor to find it ran good, found your comment on the thermtrol. It fired back up after cooling down like you said. You saved one bucks. Thanks!
Its the switch. order the switch from the company or your local vac shop. 2 to 4 screws on the handle. then go to were the hand tools are kept, there should be 4 screws. then splice the wires and put on the wire nuts and new switch and your in buiesness. ( check for a clog before repair )
I don't get your procedure to fixing the fuse in the vacuum. If you could explain it , like break it down, I could figure it out. My vacuum just shut off and wont turn back on. No matter what I do. I've taken the thing apart everywhere and still no fix. I did tons of research on my vacuum problem and a blown thermal fuse is most likely what it is. If u can help, I would greatly appreciate it.
Thanks
