Hello The circut board thinks the door switch is open.Try unpluging machine for 3 min.The restart as normal. Its more a control board issue then a door switch.
how many flashes
1-safety sensor wire broken
2-safety senor wire shorted or reversed
3-door control or wire short
4-safety sensors mis aligned
5-motor overheated or bad RPM sensor
6-circut failure, bad logic board
did you tested your led switch? you can bypass lid switch just have to be very careful after that....if it is a bad lid switch better replace it....unexpencive and more safe
Either the thermostat, fan relay on circut board or blower motor bad. Jumper the R and G terminals together on the circut board, depress the door switch and see if the blower runs, if not, check for power to motor, capacitor and motor windings. If it runs then you have tstat/control voltage wiring problem.
try your outlet,,plug something else there to see if you have current if so make sure breaker is 15 amps or better with washer on line alone..if good bad door switch..
