SOURCE: Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
SOURCE: change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: brother mfc 9880 fax/copier makes grinding noise
Probably a broken Hot Roller gear in the fuser. The fuser is the section in the back, that presses the print between a pair of hot rollers to melt the powdered toner into the paper, making the image permanent. That combination of heat and pressure makes the fuser vulnerable to breakage in any laser printer or copier. The HR (hot roller) gear is a ring around one end of the heated roller, and it sometimes breaks apart.
The MFC 9880 isn't listed on Brother's US service website, so I can't tell you whether you need to buy a whole fuser assembly or just that gear.
