SOURCE: Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
SOURCE: datamax allegro2 error
if you have it set to use thermal ribbon and dont use 1 then you can get this error..
put a ribbon in or there is a switch located inside the case near the feed switch turn it off
SOURCE: Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
SOURCE: We have Zebra Card Printer
I had the same problme and I've changed the black Intensity from 0 to -10 in : Print properties > Color Adjustment. It worked.
SOURCE: wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
