Question about Simpson Washing Machines
My simpson aquapulse 513 5kg heavy duty machine, spins washing into balls and then stops, what must I do to repair this
    Habit-Forming:
  • Simpson Expert
  • 199 Answers
You will probably find the agitator is spinning but steel bowl isn't. Either brake release is not working or clutch problem. Not an easy fix. Best to get someone out to repair it.
Posted on Nov 14, 2016
6ya staff
SOURCE:
The water is not draining out of the washing machine what could be wrong
not much info out there on this one
water pump solenoid or water pump
faulty control board timer
to empty machine run drain hose out the door
or towels and buckets
Sep 17, 2016 | Simpson Washing Machines
I hve a simpson aquapulse every time I do washing pu comes up can sme 1 plz tell me wat it means thx
PU code is the drain pump/\, This code can mean a bad pump, but most often there is some kind of restriction or blockage in the drain lines from the pump to the drain. Check for clogs/restrictions and clean them out and try again.
Dec 31, 2014 | Simpson Washing Machines
Simpson aquapulse 713
Remove the clothes and check for free movement of the drum, if there is friction then check the motor and belt assembly, check the free movement of the bearings. Also make sure that the inlet water level is good and the water level set is correct for the clothes quantity. If not the clothes will be dry on top and might cause such an issue
Oct 03, 2013 | Washing Machines
Brake band for Simpson Genesis 505 heavy duty washing machine
www.searspartsdirect.com or www.applianceparts.com. If the brake is internal with the gearbox, chances are the only way to replace the brake is with a new/rebuilt gearcase.
May 10, 2012 | Simpson Washing Machines
My Simpson 806 Heavy duty washer fills then stops, flashes SF on screen and beeps. Anyone got a solution?
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
on certain models the "sf" stands for service filter.
Jan 12, 2012 | Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
Washing Machines Logo
113 people viewed this question
Top Simpson Washing Machines Experts
ANTISPAMMER
Kardoc
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
