I keep reading solutions that tell me to lift off the front panel, but this dryer doesn't have access from the front. In the back, I can take off the panel that has all the controls in front of it, or unscrew the bottom to have access to the inside of the dryer. My question is, where is the ignitor, or how do I access it? Thank You!
SOURCE: Inglis Dryer
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
SOURCE: How do I get inside this DLE5977
There are 3 screws across the back of the top. The lid then slides back and comes off. From there it gets alot more complicated because you end up taking the front off and the bracket behind that then you can lift out the drum.
SOURCE: How do I check to see if the ignitor glow red?
you can remove the front replace the door and check the ingitor .. let me know and I can guide you step by step
krazytech
SOURCE: kenmore gas dryer series 80
small plug left side bottom remove it this will allow you to see if ignitor is coming on if it is suspect the coils on gas valve or no gas to dryer if no glow possible bad thermal fuse remove back small white object on blower housing ..if no lower panel ..remove 2 screws under filter pop top 2 clips 1 each side about 2-3 inches from end..2 screws 5/16 1 each side upper corners remove lift front off
SOURCE: gas dryer
hi
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Sorry, yes it is a gas dryer
I assume this is a gas dryer, please clarify.
