Everything else works but when i press sycronize, the display only says "data disk". What am i doing wrong?
SOURCE: need to know to burn a cd with the sony c d r rad-w500c lost my m
Go to this page and click Get Manual
http://www.retrevo.com/support/Sony-RCD-W500C-manual/id/423ag417/t/2/
The next page will ask for your email address and for you to type in the displayed code. Then it starts a Save or Open dialog.
That is all.
SOURCE: which cd-r audio do I buy.
when you buy cdr's to use with the recorder be sure to go and buy "cdr audio". You may have problems with certain brands. It really is hit or miss but Sony discs should be fine with this player but try to get a small number of cheaper disks and try to see what works well.
There is a small chance that one brand may sound better(or some people say) but I have never had one problem like this from one to another.
SOURCE: how do you connect a sony cd recorder
usually to the TAPE out sockets[coax,optical,RCA,].Im assuming its not video capable.actually,any out sockets on the amp,and IN sockets on the recorder
SOURCE: for sony rcd-w500c/w100 won't go to record mode.
Make sure you're using CD-R AUDIO or MUSIC blank discs. It won't record onto data discs.
SOURCE: Problem using cd r memorex
It IS a data disc. Consumer CD Recorders require CD blank media with the words "Digial Audio" stamped on them. It's in the manual.
