SOURCE: Frigidaire Front Loader Ripping Clothes
Frigidaire washer sucks. I'm tired of this useless machine ripping my clothes. You need to change your bellows(boot) kits around the door on front load. I have changed this kit twice now and each time, I spent $200 in repair fees. I wished I never bought this washer. Will never recommend to anyone i know.
SOURCE: maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
SOURCE: Maytag Bravo washers is staining my
the upper transmission seals bad its under the tub agitator and letting oil into the water called "wash back" you need to replace this seal and stains will disappear
SOURCE: washer is ripping my clothes
Hi I have had this problem. Per Technical Service Pointer W10539798, The solution is to replace the glass door to the washer with a redesigned door AND replace the large rubber gasket or bellows between the tub and door. I found the new door (used: part number W10388315 or 8540428) and bellows (new) separately on amazon for about $130 all in. Installation took a couple of hours. Problem fixed.
