Question about Apple iPad Tablets & eReaders
7.5 earthquake stoped my iPad in its tracks. Main computer working OK. iPad works offline, and turns on OK but will not connect to the internet.
I have ttried everything that I know by going to Settings, but can find nothing wrong. Have also turned off and on several times. I am worried now that I have altered a setting and made things worse. This has happened before with a lightning strike, but all I had to do was put in the password again. Struggling now with this event.
6ya staff
SOURCE:
Anonymous
SOURCE: R15 wont turn on
I have the same problem and when I send it to be checked by toshiba technicians they told me that the motherboard is not working anymore. If you could find the price of the motherboard let me know?
Posted on Sep 23, 2008
SOURCE: How do I transfer photos from my computer to my iPad?
When you connect your ipad to computer Itunes must be recognized it .
Make sure itunes version 9.1 installed.
If not then download from this link click here
Make sure ipad is enough charged.Try different usb ports.Makes ure usb cable is working fine.
Uninstall usb drivers from computer then check.For that press windows key +R so you can see run type in run "devmgmt.msc" then press enter.
Then you can see device manger uninstall all usb drivers 1 by 1 then it automatic install usb drivers.
restart iPad, first turn iPad off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPad will turn off after a few moments.Next, turn iPad on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPad not responding? To reset iPad, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
Then check then you can sync it with itunes in computer.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 07, 2010
jeff39b
jeff39b
SOURCE: I had bought an ipad
I was very happy when I got my hands on the new iPad. I didn't notice this at first, but when I took the tablet into my backyard, and my iPhone was able to pick up my router signal without a hassle; the iPad didn't pick up the network at all. This became a nightmare for me. A friend suggested trying the "Forget This Network" reset method, which used to work on the older models, but this didn't improve the wifi range at all. Right when I lost all hope, I came across WIRED magazine and found a review of Pong Research cases, After seeing the great feedback on their products, I bought one and it finally solve the <a href="http://www.pongresearch.com/new-ipad.html">new iPad 3 wifi issues</a> . The back cover has a built-in antenna in between its layers, which redirects and boosts the signals and range, allowing me to getting connected from much further away.
Posted on May 29, 2012
Marcelo
  • 7 Answers
SOURCE: ipad will not turn on
Hey i just learned how to fix the white screen of death all you do is hold the home button then while still holding down the home button hold volume up button then while still holding those buttons go head and hold the power off button and hold that until you see the apple sign and THIS REALLY WORKS SO TRY IT
Posted on Jun 15, 2012
Jim Thomson
  • 1099 Answers
SOURCE: On my new iPad 3, when I push the home button to get out of a program, it does not work. I push & hold and nothing happens. I have rebooted the iPad several times, nothing. What should I try next.
It may be a hardware fault, what I would do is given that it is a new ipad take it to the local Apple Store and they will either replace it and have it repaired.
Posted on Dec 11, 2012
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
Need to download iOS 8.0.1 on my apple ipad keeps telling me it failed because I am not o internet, but I know that I am connected to the iternet what is wrong?
if you have laptop/desktop computer you can sync the iPad with iTunes and download iOS 8.1.2 there:
Upgrading iPad to iOS 8: Through iTunes 1. Backup your iPad
Open iTunes. Select your iPad in iTunes and click Back Up Now.
2. Restart your iPad and your Computer
3. Download and Install the Update
Go to iTunes -> Select iPad -> Check for Update -> Click Download and Update
Whichever method you choose, the process will take quite some time to work depending on how much free storage you have on your iPad, your internet connection, and how Apple's servers are doing with upgrades. Occasionally, Apple will either not let you download the upgrade or it will fail. For iOS 8, you must have an iPad 3 or newer. This does not work with the original iPad - if something goes wrong, restart your device, and try again.
How to Upgrade to iOS 7 on an iPad or iPad Mini
How to Install iOS 8 When Your Device is Low on Storage need-download-ios-8-0-1-apple-ipad-keeps-u3wnnnxjlb3ct0ebur4t0xqn-1-0.jpg
Sep 26, 2014 | Apple iPad Tablets & eReaders
With iPad must I join an internet even tho it is connected to my desktop usb?
Simply go to Settings-second down on the left menu, choose Wi-Fi and on the right menu, your home (or wherever you are) wi-fi connection should appear by name. Then simply touch the one you want to connect to. You should see the choice you made on the left menu next to the word Wi-Fi. I only connect my iPad to my computer to charge it occasionally via USB.
Sep 20, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
Sep 07, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Why doesn't the touch work on my ipad
The iPad's touch screen should always work, unless it froze. Try and restart the iPad (hold down the button on the top edge, close to the camera lens until the iPad turns itself off, normally a few seconds). If it doesn't work after a restart, you may need to reinstall the system, which you can do from iTunes (attach the iPad to your computer, open iTunes and choose 'Restore iPad' - you need internet connection to download new system). Have iTunes back up your iPad before restoring it, if possible, or data will be lost.
If none of this is possible, you may need a repair at a service centre. Good luck! :)
Aug 18, 2014 | Apple iPad (16 GB) WiFi Tablet PC
If my computer does not have internet can i still connect to netflix
Can your computer connect to the internet? If it can, it just means that you have a wired internet connection and not a wifi connection on the computer, which means your iPad is just connected to your home network via wifi. If your computer can't access the internet or you know you don't have internet service at home, then you either have cellular service (3G/4G) or your iPad is connected to some other available WiFi from someone else's service.
Aug 15, 2014 | Apple iPad Tablets & eReaders
Ipad will not switch on
You could try to do a hard reset. Hold down the power button and the home button at the same time until the device completely restarts and the Apple logo appears on the screen.
If that doesn't work you may try connecting the iPad to a computer and restoring the device using iTunes.
Hope that helps!
Jul 31, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Bouncing balls won't load on. Facebook
Call Zynga's Phone#: 800-762-2530
How to reach a live person: Dial 3 when recording begins
Aug 15, 2012 | Apple iPad 32 GB 3G Tablet PC
IPad 3 Printing
You can download hp eprint from appstore.Works with variety of printers.
Aug 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
