Question about Exercise & Fitness
Vision Fitness Treadmill t9800. e7 speed stall at start, display lights up fine, belt does not run at all. Tried unplugging the RPM sensor but same result
T9800 vision fitness
  • 6,694 Answers
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Nov 18, 2016
6ya staff
SOURCE:
Stuck key error on my treadmill
Sometime talcum powder under the thread will get it working again, but you may eventually need a new tread. Less likely, a problem with the motor especially if it's underpowered.
Jul 31, 2016 | Vision Fitness - T9800 HRT Full Commercial...
Treadmill overspeed.
hi.
i think the problem is with your touch switch panel.
regards,
nuwan
Jan 20, 2014 | Vision Fitness T9550 Folding Treadmill
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
Error message "Speed Stall" stops will not run. :(
You must try a) LUBE very well the Deck belt and walking belt b) Recalibrate the machine.
If after this situation persist.
You must replace the EPROM(software is coming inside, and can be corrupt), call to the company.
for to get it.
Blessing.
How To Lubricate Treadmill
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 06, 2017 | Tunturi Exercise & Fitness
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Feb 28, 2010 | Exercise & Fitness
Exercise & Fitness Logo
277 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
