If the clothes are reasonably even at the spin cycle, then this is caused by worn out suspension rods,the out bowl is supported by 4 sprung rods, one on each corner you need to replace a set of four,if clothes keep all going to one side the replace the capacitor
problem is failed air dampeners on the ends of the tub support rods
set of 4 rod assemblies from a service agent spares cost around $90.00 and will take you around 1 hour to replace or a technician about 15 minutes
Two man job for the novice. Can be done by one person if you have done it before but difficult. You have to raise the top deck. Remove 2 screws at front & 2 at rear of deck. Get your helper to hold up the deck. Then remove & replace one spring at a time. Lift suspension rod up & remove the plastic holder/swivel at top. Drop rod down, tip machine back as far as you can and pull rod out of bottom holder. Feed new rod up. Stand machine up & hook top of rod back in to swivel holder. Then do same with next one.
