SOURCE: Our 42" plasma tv will not show a picture or anything else.
I have parts from my tv for sale 42" daewoo plasma
email me at [email protected]
SOURCE: My RCA model D52W20 will not fully power on when
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
SOURCE: Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Testimonial: "Plug and outlet are ok, well drop it off at best buy to fix. Thank you."
SOURCE: red distorted color near top of screen not having
Reset will not cure a convergence problem.
this model (ws-65711) uses a single convergence chip located on the middle circuit board (see photo).
If convergence is skewed and will not adjust in customer menu the chip needs to be replaced.
Good news: I have start to finish, step by step instructions for this repair in this set. They tell you everything you will need and exactly how to do the repair.
No two sets with convergence problems will look exactly the same but I will also attach a few photos of this kind of trouble.
If the photos or what I have told you told you something you did not know and you want the instructions (free) rate this solution as very helpful as I do this here for free.
SD TECH
CONVERGENCE CHIP USED IN THIS MODEL.
TYPICAL BOW FROM CONVERGENCE PROBLEM
ANOTHER SET WITH CONVERGENCE PROBLEMS
Testimonial: "This seems to be the problem I'm having Tks for the information great help look forward to getting your instructions to replace the chip. "
SOURCE: the tv will not turn on it starts blinking red
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?) Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself it will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I
