It turned off Ok for 2nd rinse.When finished a smell of burnt rubber issued from the inside of washing machine. What's going on?
SOURCE: GE Washing Machine
Saragary,
It sounds to me like the safety switch for the washer lid is faulty or just out of adjustment (you'll find an arm sticking out of the lid that corresponds to a similarly shaped but larger hole in the jam of the lid and that is where the switch actuator should reside).
Or, your timer might be at fault, since it completes cycles once you manually advance to the next one.
Eliminate the safety switch as the possible fault before moving on to the timer itself, as the timer is more costly.
Good luck.
SOURCE: burning rubber
Hi
You have a broken motor coupling, while you are down to the pump check for something jamming the pump,..
Please follow the procedure...
First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft.
Thanks for contacting Fixya.com
