SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
SOURCE: KONICA MINOLTA PagePro 1350W
You have to connect it to exactly the same USB port. For every time you connected to a different port compared with the last one, a new copy will be installed.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
SOURCE: Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
SOURCE: Konica Minolta PagePro 1390 cannot print in
Try using XP drivers, you may have to download and install manually from kmbs.konicaminolta.us
SOURCE: DRIVER NEEDED: KONICA MINOLTA PagePro
http://onyxftp.mykonicaminolta.com/download/Search.aspx
search in this link.
