This is fairly a common problem experienced by all printer users. If your Epson 7880 printer doesn't recognize the newly installed ink cartridges, you should check for the possible causes that may encounter this problem.
• Make sure that you have updated the drivers and software for your printer.
• Check that the ink cartridge is placed correctly in your Epson printer.
• Sometimes, dirty or the faulty cartridge chip or the damaged contacts can be the reason of this problem. So, clean the contacts to solve the problem.
To find out more possibilities and other solutions, you can also call on the Epson printer customer care number to directly gain access the help of the technician to solve the issues.
Epson Printer Tech Support Number 888 604 2301
