SOURCE: low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
SOURCE: Midland GXT800 radio, opened, reassembled, won't charge now...Help!
hi ive got a midland 3001 and i carnt find any one to speek to ?
SOURCE: one of my 1008 walkie talkies will not turn on
the fault radio can be repaired, by contacting the following
www.fastradios.com/two-way-radio-repair.html
www.wireless.com/service-repair.htm.
for your repairs more will be given
SOURCE: Oops, misplaced my manual for
bobduffy39,
Channels are selected by tapping the center button once then using the arrows. The next tap of the center takes you to the CTCSS, DCS, and other functions follow. When scanning simply tap the transmit button and it should stop on the selected channel. Channels 8-14 are FRS channels at 500mw. These are the preferred channels to use for most people. 1-7and 15-22 are considered GMRS and requires a FCC License. Many people have been known to use these channels without having the license. This form of pirating is not recommended. I have included these links which could be of help to you.
To find a PDF Manual for Midland LXT310:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
To locate information on obtaining a GMRS license:
http://wireless.fcc.gov/services/index.htm?job=service_home&id=general_mobile
JTRadiojunkie
SOURCE: I bought 6 sets of
The batteries have likely been damaged from being on the chargers too long. Try trading a known good battery into the non-working radios and see if it/they will work with a good battery. If so, replace your batteries, and then only put the radios on the charge when they need a charge, such as after the radios have been used 8-10 hours. Longterm charging can quickly age batteries. Life expectancy of a battery is 18-24 months with good care.
Best regards.
