SOURCE: I can't hear any speech when I play a DVD, but I have all other sound.
Yes what you heard is correct,look for center speaker connection.If it is correct then connect it thru coaxel or digital out and see.
SOURCE: Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
SOURCE: No surround sound with Prima HT-TW57P DVD System
I realize this may sound silly but it could be the disc your are playing. Some DVDs are not mixed for surround sound and thoes that are produce very little sound from the rears.
Rear speakers were meant for effect, not meant to distract you from the picture.
Give this a try, get a movie playing that is 5.1 surround sound. Check that the home theatre is not set to stereo mode, if it is change the surround mode on the unit. Now that you are in the middle of an action scene disconnect the front speakers and see if there is background noise comming out of the rears.
If its still dead let me know more details about the system and I will work on a solution.
Cheers,
SOURCE: My Surround sound DVD player
Panasonic error code F61 is for an output /power problem. Most likely it will need the output IC replaced. But check that the fan(s) are running a bad or stopped fan will also cause F61.
So the fan needs to be replaced. My system had the same problem and the fan was making a terrible noise. I had this repaired and the system is as good as new.It is better that you take it to the technician for the repair.Still then i am giving you little help.Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
Or else that is if your fan is working fine then your iC needs to be replaced and it is best left to a technician and Panasonic is the only supplier that I know has the part.
If you have a repair shop repair the problem, the cost could be $150.00 or more to repair.It would surely solve your problem.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: what causes no vocal sound but background sound an...
Try changing from surround sound to normal
please rate my help++++Thanks for using FIXYA
