Question about Sennheiser Audio Players & Recorders
How do I remove the pc board from sennheiser set 180 so I can repair the left hand switch
How do you repair a sennheiser sk100 jack socket
I assume you mean the mic plug/jack. Bent pins or broken connectors will require a new jack and/or plug installed and they are not easy to do. These 3.5 mm jack connectors require both a light touch during install and soldering. If you're a pro then start shopping for a replacement 3.5 mm mono jack but be warned. The jack may solder directly to the PC board....which reminds me. Look for broken connections from jack to PC board..a common failure point and resolder as needed.
May 01, 2014 | Sennheiser Audio Players & Recorders
Why is there no sound even in bypass mode?
The bypass switch developes dry joints after some time. The earpad has to be removed and the speaker plate unscrewed and lifted back. The cct board connected to the switch will now be exposed so the switch legs can now be resoldered. Reassemble and you should be good to go.
Apr 28, 2014 | Sennheiser PXC 450 Headphones
There's no sound coming out from left earphone
Try your headphones in a different audio device. If the problem persists than the headphones have a split in the wiring for the left earbud. If you are under warranty then Sennheiser will happily repair your headphones.
May 03, 2011 | Sennheiser Sport II CX 380 Stereo...
What would it cost to repair the on/off switch on ew 100G2 sennheiser ?
To repair the on/off switch of the handhelt it would cost abt 15 minutes and $2,00 for the switch.
So that would be $20-25.
Reagrds Gerard
Oct 03, 2010 | Sennheiser 100/500 G2 Series Wireless...
Sennheiser MM100 bluetooth not working
Yes I had the same problem. Under some circumstances the MM100 freezes (didn't figure out when just yet). It's a software issue inside. Solution: open left speaker (the side with the charge connector and hence the battery). Discharge the battery (or just short circuit for half a second) and it works again. Sennheiser should built a reset button on these things.
Mar 20, 2010 | Sennheiser Radio Communications
WHAT PLACE repair ew 100 micro, d ON/OFF switch
You're local Sennheiser dealer can fix it, no problem.
The repair takes a half an hour.
Regards,
Gerard
Mar 04, 2010 | Sennheiser Audio Players & Recorders
On off switch broken
You can order those switches by your local Sennheiser dealer. It's not a hard job to repair it.
Your dealer can also do that, I'll think your switch is repaired for $20.
Regards,
Gerard
Jan 31, 2010 | Audio Players & Recorders
Frontal panel setup for P17G/1333 (V1.0A) mother board
I have found a manual for that motherboard at
http://static.tigerdirect.com/pdf/PCChips_P17G-1333_Manual.pdf
In general when troubleshooting this type of problem minimise the amount of problems by removing any cards and or memory - whilst still allowing the machine to function. try reseating all memory and cards as well, as these can sometimes come loose during transit.
May 26, 2009 | HP D9840-69007 - System Board Motherboard
Power switch went bad. need to know which pins attach to which wires
Looking at the front of PC remove the left side panel. Now looking in at the board. There are two rows of pins in the lowest right hand corner of the board. Your PWRSW is your power switch. Its a two pin connector. The ground wire will be black or white. The ground faces to the right & connects at pin 4 counting from right to left. Power switch takes up pin 4&5.
All done. If tech switched the wires by mistake than flip the connector 180*.
Jan 01, 2008 | VIA ASUS A7V8X-MX KM400 Chipset Ultra...
65 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
