SOURCE: katana II by sanyo on sprint network
Unfortunately it will not work. TMobile uses GSM technology while Sprint is on CDMA.
SOURCE: remove sim card from lg lx160
It is under the battery. there is a metal tab that holds it in place.
Good Luck
SOURCE: I need to find out what my SIM PUk pin is to unblock my SIM Card
hi,
just call your network operator and provide them with your phone number and sim serial number, which is on the back of your SIM card. then they will provide you with the PUK code.
rate me if it solves your problem
SOURCE: SPRINT SANYO PRO 700
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
These directions are for an AT and T phone, but other than that would be the same for any carrier.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card.
You can obtain your phone's PUK code from your carrier in one of these ways:
Log in to Your account.online
Use a Technical Support Chat
Contact your carriers Customer Care
Get Your Phone's PUK Code Online
Go to the Phone/Device page.
From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
