CarGurusApr 7, 2013 - I need to find out what transmission is in a 1999 gmc sierra 1500 pick up 4x4 extended cab. ... Good luck. if the transmission is bad and you KNOW that for a fact, just go ahead and pull it ... My trans went out yesterday and I found one and wantto make sure it fits before I buy it. ... Used GMC Yukon Denali".
CarGurusAug 15, 2014 - Is the transmission in a 1999 gmc yukon and a 2000 Yukon Denali the same. ... Does anyone know where I can get a fairly cheap used motor from in or ...Need a good fairly cheap motor for my 99 Gmc Yukon Denali 5.7L V8.
you might want to check the wires going to the temperature sensor on the engine make sure it hasnt rubbed the protective coating off, this can give you a false reading, the safest way is to put a manual gauge in place of the temperature sensor and run engine to make sure the engine is not overheating. You can pick up a cheap manual temp gauge at your local parts store and install the temperature probe into the hole where the temp sensor was located and run the engine. It sounds like you have a guage malfunction. But is better to be safe than sorry.
I would say start at 4.5 to 5 quarts and check after starting the motor. Slowly add to the full line on the dipstick. Some GM V8's can take up to 6 quarts.
On some models of general motors starter shims are required to maintain the recommended clearance between the starter and flywheel. If not, then the starter will hang on the flywheel after motor is started and damage it (The teeth are bottoming out when this occurs). They sell starter shims at the auto parts store. Hope this helps.
it is 8 years old and it is the most used window. it needs a new regulator, buy one at a parts store or on ebay and pay a glass shop to put it in for you.
Your there, unscrew 10mm bolt's that hold window regulator, and two small bolts that hold window to regulator, used something to hold window up, while window regulator is out, most part places will sell this part, it's call a window regulator, there no repair for the cable, assembly will have to be replace.
