The message "Time for periodic maintenance 0008" on your Toshiba 307 model photocopier means that it is time to perform routine maintenance on your machine. Here are the steps to clear the message and reset the maintenance counter:
Press the "Utility/Counter" button on the control panel.
On the touch screen, select "User Management."
Enter the administrative password (default is "123456") and press "OK."
Select "Maintenance Counter."
Find the "Periodic Maintenance" option and select it.
Press the "Clear" button to reset the maintenance counter.
Press "Exit" to return to the main menu.
After these steps, the "Time for periodic maintenance 0008" message should be cleared, and the machine should be reset to zero. It is recommended to perform routine maintenance on your photocopier periodically to keep it running smoothly and to prolong its lifespan.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine. to check how many copies you have press the user tools/counter button and then press counter.
Well need to replace the drum and developer running F8 with out changing the developer is not good, also make sure you clear the counter before replacing the drum and developer done toghter
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
