I have fishing blue light.According to what I'm seeing I must open up tablet and reset battery. Please explain how or show me how. I am not pleased after only purchasing it 3 months ago. Please help or I am done buying Samsung in the future. Help Help Help.
SOURCE: My samsung galaxy tab from
When its off condition
do Volume Up + Power-button for 3 secs
you will see a screen with exclamation mark with android and some font written in Blue
Do wipe data using Home key to select and volume keys to navigate
then do reboot to system i think it shd fix your issue.
SOURCE: How can i connect my 3G internet on Samsung Galaxy
This should help you out:
http://www.techtin.com/gadgets/how-to-turn-on-and-turn-off-3g-on-samsung-galaxy-tab/
SOURCE: I bought my Samsung Galaxy
It sounds to me like you have an issue with your Galaxy Tab's charging port.
Fortunately it is still under warranty if you've just recently purchased it.
Take it back to the store or contact Samsung for a warranty replacement. They may be able to help you recover items from the memory.
Hope this helped!
Thanks!
SOURCE: i am trying to upgrade
Good day. I''m afraid you might have accidentally got the Operating System of your Samsung Tab corrupted. Im referring to your firmware. Usually if the firmware upgrade failed you need to retry it until it be successful. If you restart it or discontinue the process it will cause your Samsung Tab to be corrupted resulting into failure of the boot up process. You might need to contact samsung tech support for this or bring your equipment to the nearest center. They might need to check the software install and usually their software specialist will fix it for you. Sorry for what happen with your tab but i know the samsung repair center can fix it for you. Hope this information will be helpful to you. Have a great day.
Testimonial: "Thanks for your immediate response regarding my problem. more power to fixya....."
SOURCE: i just bought a samsung
Hi!
First of all in user's guide manual says that this tablet works just fine with only 3 IM : 1.Google Talk; 2. Windows Live Messanger 3. Yahoo! Messanger.
Try one of those to see if the camera button appears.
However, if you need more information you can find them here: ( http://www.userguidemanual.com/samsung-galaxy-tab-gt-p1000-tablet-manual-user-guide-french-english/ ).
*This link allouds you to read and download free user's guide manual (in PDF format).
I hope this will work!
Have a nice day!
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
