Question about HP PSC 1610 All-In-One InkJet Printer
My HP PSC 1610 wrecks SD cards, destroys data
Several weeks ago I inserted an SD card into the printer in order to get pictures from my camera.
After a couple minutes of reading and uploading about half the pictures, the warning lights came on with Card Error.
I had not pulled the card out prematurely (i.e. before Safely Removing). I simply used the slot for the first time. This happened during upload.
But the card would no longer be used anywhere- not in the printer, nor in the camera. I lost half the pictures and could not even reformat the card.
OK, I figured, bad card. I purchased another SD card- different brand. I took the card on vacation last week and came back to upload the pictures through the printer. Same thing happened again. Again, I did not pull the card out unsafely. I just used it as expected and halfway through upload, it ceased to function.
So now I'm down 2 SD cards along with a couple gigs worth of precious memories, and the printer, it seems, simply does not perform as expected. Worse, it has done harm.
6ya staff
SOURCE:
Anonymous
SOURCE: Memory card error
Memory cards larger than 2 GB are not supported with Photosmart printers
Posted on Feb 09, 2009
Basti
Edgar Allan Pagayona
  • 1447 Answers
SOURCE: Memory card error when using sd card to download pictures
Hi
Whats the memory size of your SD card? this printer only support 1gb card.
Thanks for using Fixya
Posted on May 13, 2009
Anonymous
SOURCE: memoy card error
Im using XP and have the same problem. I have no Memory card in the slot. How do you clear this error?
Posted on Dec 25, 2009
Anonymous
  • 51 Answers
SOURCE: I have a HP PSC 1610 All in one printer and I
If using the Card Reader -
The HP all-in-one has detected an error with the memory card.
1. More than one memory card is inserted in the HP all-in-one.
2. An incompatible camera is connected through the camera port.
3. A memory card is inserted and a digital camera is connected at the same time.
Solution:
Remove and reinsert the memory card. It may be inserted incorrectly. If the problem continues, the memory card may be defective.
Remove one of the memory cards. Only one memory card can be used at a time.
Check the user guide that came with the camera to see if it supports PictBridge. If it does not, try using the cable that came with the camera to connect the camera to the USB port on the back of the HP all-in-one instead of to the HP all-in-one camera port. If the camera does support PictBridge, make sure the camera is set to PictBridge mode. See the user guide that came with the camera for instructions on how to do this.
Remove the memory card or disconnect the camera. Only one can be used at a time.
You might try the following - Reformat the memory card in the camera or format the memory card in a Windows XP computer by selecting the FAT format.
Hope this helps!
Posted on May 01, 2010
momentomick
SOURCE: i have a hp psc 2355 printer everytime i insert
I had the same problem with my HP L7590 All In One. After trying a number of things to reset nothing worked. Then I tried this just as a last resort and it worked.
Insert the/a memory card( it will tell you that you can only use one card at a time).
With the card still in turn off the printer using the power button.
Wait for 30 seconds then turn power on again.
The screen should say reading card. So wait for it to finish reading and all should be fixed.
If this does not work, try again using a different card.
good luck
Send me Kudos if it works.
Posted on May 03, 2011
How to scan HP1610
Refer to Chapter 8 in the following manual:
HP PSC 1610 All-in-One
You can scan to an application you have set up on your computer or you can scan directly to a memory card you have inserted into the printer.
Aug 10, 2010 | HP PSC 1610 All-In-One InkJet Printer
My HP PSC 1610 All-IN-ONE will not read SD-cards. We have had this problem in the past and now that my son's birthday came, I cannot upload pictures to my computer.
Please try unplugging the Printers USB cable reboot the PC, and after it is at desktop, THEN plug in the printer, Now it should work OK, Also Try ANOTHER USB port too.
If that doesn't work, again unplug the printer and reinstall the drivers from the DVD. etc. Now try again. If it still doesn't work, perhaps it is the SD card? In fact, I guess FIRST you should check that SD card and see if it can actually be read?
Aug 08, 2010 | HP PSC 1610 All-In-One InkJet Printer
To print photos my machine requires a memory card. What card should I ask for and where/how do I install it?
Hello!
You can print photos from your computer too. Usually, people use memory cards from their digital camera, when they want to print photos directly from the memory card. If you do not have a digital camera or any other device that uses a memory card (i.e. a mobile phone), I am not sure you need one in order to print photos. However, here is the answer to your question:
You can use several memory cards in your printer, but only one memory card at a time! You can use:
  • SmartMedia, xD-Picture Card (fits in bottom right of the slot)
  • Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro
  • CompactFlash (I, II)
  • Secure Digital, MultiMediaCard (MMC)
Here is a picture, so you can see how to install them:
You can buy either one of these memory cards, it's up to you to decide which one you want.
Hope that helps!
May 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
I have a HP PSC 1610 All in one printer and I tried putting my media card in the SD slot and it tries to read the card but the red light flashes and says memory card error. HELP Please!
Solution:
Hope this helps!
May 01, 2010 | HP PSC 1610 All-In-One InkJet Printer
When i plug an sd card into my hp 1610, the pictures are very very slow to show up on my computer screen, and when they do show up it doesn't want to print them. The copier still works fine. Is the problem...
USB ports on a computer are either:
* USB 1.1 -- up to 11 megabits/second
* USB 2.0 -- up to 20 times as fast as USB 1.1
So, be sure to connect your printer to a USB 2.0 port on your computer, to get faster file-transfer.
As to the "does not want to print", what error-message(s) are produced?
If you copy a picture to your My Pictures folder, can you right-mouse-click on the picture, and "print" from there (after removing the SD card from your printer) ?
Jan 02, 2010 | HP PSC 1610 All-In-One InkJet Printer
How do I transfer pictures from my computer to an SD card? the files transferred but the images do not appear when I place the card in my camera.
You can use memory card reader or simply connect the device like digital camera or mobile phone to PC or laptop using data cable. You can also use bluetooth or infrared to transfer data.
Dec 12, 2009 | Dynex USB 2.0 5-in-1 Memory Card Reader
Memory card error on hp psc 1610
it is a logic card problem.so you can checked it from vendor.
Aug 16, 2009 | Office Equipment & Supplies
Cannot get pictures off of SDHC Card 4GB
Could be it only supports SD cards up to 2gb but not SDHC.
Jun 16, 2009 | SanDisk 4GB microSD High Capacity Memory...
HP PSC 1610 All-In-One - Memory card Error
Pulling out the card without using the 'Safely remove Hardware feature' risks corrupting data on the card. Reformat the card in the camera. Also with compact flash it is a simple matter to wreck the some of the tiny pins in the card slot. Check out both these and come back
Sep 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
115 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
