Zanussi Washing Machine Error Code = E40 ?Error Code Definition = The washer door is either open or not properly closed.? What To Check or Repair = Check that the door is completely closed. Check that nothing is blocking the door from closing.
Zanussi Washing Machine Error Code = EH0? Error Code Definition = The electrical supply is not stable. Wait until the mains supply is stable.? What To Check or Repair = Check electrical circuit breaker. Unplug the washer for 10 minutes to reset.
its just dirty contacts if you can open your keyboard, clean contacts with non rubber eraser like the ones used by engineers and draftsmen. also include the rubber contacts under the keys
Are you saying the lights are blank and when you press the start buttion nothing happens?
One reason the controller can shut the power is that the heater overload protection thermal resistor has opened. Unfortunately the only way to fix this is to replace the entire heater plate at the bottom of the drawer.
To confirm if the controller is operational or not, press Keylock and Start/ Pause button together for 5 sec (press Keylock first) and see if the Lights light up. If nothing happens then either the power has shutoff as mentioned above or controller is faulty.
Depending on your familiarity with such equipment you could try to replace and fix. I am not quite sure what the new model you mention is. I believe all DD603 models have power to the 2 drawers coming from the base board.
