Washing Machines Logo
Richard Mullen Posted on Dec 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool awm8121 washing machine. It starts to fill then stops itself and drains. Ran diagnostic test and it has fault code 1. Inlet hoses and filter are clear. Any ideas appreciated thanks
its222
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Dec 28, 2016
its222
Expert
Level 2:
New Friend:
Answers
59
Questions
Helped
23592
Points
139
Hello: Fault detected malfunction code 1 for your model states
"Water not entering or not detected". Check inlet tap, cold inlet valve, pressure switch. Sounds like you said water is going in and has good flow, but may not be "detected". Could be a sensing problem like pressure switch.
5 Related Answers
Anonymous
  • Posted on Jan 05, 2008
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Anonymous
  • 725 Answers
  • Posted on Apr 05, 2008
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
TonyaP
  • Posted on May 07, 2008
SOURCE: Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Anonymous
  • 267 Answers
  • Posted on Oct 04, 2009
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Rod Wilson
  • 4 Answers
  • Posted on Dec 04, 2009
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Whirlpool Cabrio WTW6700TW1 skips wash cycle and stops after 14 minutes to oL
oL is an Overload error. Try running a cycle empty.
If oL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent. Close lid and press START/PAUSE.
oL - Error Code - Washer - Product Help ' Whirlpool
https://www.google.com/search?q=whirlpool+cabrio+ol+error
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
2answers
Whirlpool washing machine AWM 5100 has stopped going thru the full cycle.
My machine did a similar thing and in my case, it was debris in the filter. It took several clear-outs before the object appeared.
1helpful
The wash cycle is taking a lot longer to do, for example the 30 min wash is taking 1 hour and sometimes longer, the motor seems fine, could it have something to do with the pump
Hi.
When the cycle hangs it means that because of a fault the conditions to advance are not met.
If the washer hangs at start (filling), then there is either a problem with water pressure, blocked inlet, or water flowing back from drain hose because of incorrect hose settings (called siphoning).
If machine hangs mid cycle, then it is often a temperature related problem. Check thermostat and element or check hot inlet and thermostat if dual inlet. Testing requires disassembling and use of the multimeter.
If machine hangs mid cycle or end of the cycle (before spin), then it can be drain system. Check drain hose, drain filter attached to pump and check the pressure switch.
Most machines have a service sheet hidden inside the control panel assembly. The tech sheets shows how to run a diagnostic cycle that will tell where the problem is.
Most common faults resulting in long cycle are heat-related and drain problems.
Regards.
Ginko
Whirlpool cabrio washer starts to fill and then quits almost immediately and then the LF code comes on. I have run the automatic diagnostic test and the water inlet valve seems to work fine. During test...
Try cleaning your inlet valve filters. Turn off your water supply and remove the hoses from the washer. The filter screens are located just inside of the valves. Just twist them out, clean, and reinstall.
Good luck.
4helpful
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Not draining properly (very slowly, causes error code). drain hose outside of washer is properly connected, no kinks, no obstructions. Error code "04" comes up repeatidly. After it finally drained we ran a...
The3 problem is more likely to be in the pump itself. No diagnostic except what you have jsut described. Open the outside covers and access the hose to and from the pump. More liokely on the inlet side and check the hose and the pump entry hole.
Please rate my help++++Thanks for using FIXYA
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
Whirlpool AWM8121 stops working mid cycle. Bottom two lights flashing on spin speeds.
Fault code 3 = Drain failure or not detecting empty drum.
Check pressure switch, blocked drain, drain pump.
See link below for service manual.
http://www.user-manuals.com/advanced_search_result.php?keywords=857081253000&forward=plist
2answers
Kenmore 22082
OL on my washing machine
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
