Washing Machines Logo
R
Robert Pitts Posted on Dec 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Simpson ezi sett 7.5 always fills to full even when set to low. i have replaced the pressure switch and still fills to full.
Peter
Level 2:
Champion:
  • Simpson Expert 203 Answers
  • Posted on Dec 26, 2016
 Peter
Simpson Expert
Level 2:
Champion:
Answers
203
Questions
0
Helped
97303
Points
471
Check the rubber hose from the pressure switch down to the bowl for any holes or splits allowing the air pressure to escape. Also check that water valve is stopping the flow. Start to fill then press pause. Water flow should stop immediately. If it keeps flowing or is slow to stop then replace the inlet valve. Try it several times to be sure.
My top loader Simpson ezi set washing machine over fills what can I check to get it working normal again
check the small tube to the level pressure switch
check the switch is working
check/replace the water control solenoid / diaphragm
tests are
with out clothes
select a low level wash
listen as the water flows in
when the tub is about 1/2 full the water solenoid shouf make a clunk sound and the water cuts off
at the same time the wash cycle begins
if the water comes right up and there is no solenoid sound then check the small tube or the water level switch
if there is the sound but the water continues replace the diaphragm in the solenoid
My simpson ezi sensor will not fill on wash cycle, the water enters very slowly
Check the pressure on the incoming water pipe (make sure stopcock/isolation valve) fully open then check that valve opening fully (this may be able to be removed) will be one or the other :)
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
2helpful
2answers
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
2helpful
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
1helpful
2answers
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
Hi, i have an Simpson Ezi Set 950 - Top Loader that im looking at bying online that needs a part 4 runing order, just wondering if u knw if and were i can get the part witch is (main Bearing) for it and if...
Hi just read your posting.Now how old is this Simpson.When I have replaced bearings in the EZI SET range of washing machines I always have to change both bearings and the main seal as well.Can you tell me why you need to change this bearing,Is the machine noisy on spin?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
5helpful
4answers
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Top Simpson Washing Machines Experts
vince
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
