Hello, my whirlpool topload washing machine won't spin after it rinses..it makes this loud noise and struggles as it tries to spin. at first i though it was a bad water pump which i had replaced, but it didn't fix the problem. any suggestions?
There is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
No these machines are belt drive. your problem could be caused by a bad door switch as a safety mesure since washer goes into high speeds rpms of 7,000 plus
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
does not rinse or spin ' repeats wash cycle
makes a loud banging noise when in first cycle and wont rinse
