In starting of machine the the error code show in the panel
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
Good luck and please rate me, thanks.
SOURCE: Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
SOURCE: Ricoh Aficio MP 4000 sc 870 error after power cord
SC870 = Address Book Data Error. This is most likely a hard drive failure especially considering the power loss. This is about a $175 repair in case you want to call around locally and get estimates to replace the drive. There is an outside chance you can get someone to walk you thru the Service Mode and do the following to reload the address book:
1. Enter the SP mode
2. 5846-50 (Initialize All Address Book)
3. Turn the machine off then on again.
Good Luck
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
