Tablets & eReaders Logo
Manual for ASU-T102H-DR-GR
ASUS TRANSFORMER MINI 10.1 INCH
How do i reinstall playbook on my asus tablet?
go to google play store and type what you need in or type google books
Print spooler not working google cloud print
https://support.google.com/cloudprint/?hl=en#topic=4456286
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
Asus tablet owners manual/availability
Hope this link helps U... Copy & Paste the below Link in an browser
https://www.google.co.in/?gfe_rd=ctrl&ei=r9sRU4e7HZfCuATDxYGgCw&gws_rd=cr#q=ME172V-A1-GR+manual
How to connect an asus transformer to a phillips picopix 2055 projector ?
you cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
Need Asus EEE Pad Transformer Manual in English
Here is a link to ASUS support for you pad. you will need to put in the OS, and then scroll down and you will see manual. In my case 43 were available. Eglish was the second one down. Follow the instruction on the page, it looks like you have to do this via your phone.
http://support.asus.com/download.aspx?SLanguage=en&p=20&m=Eee+Pad+Transformer+TF101&hashedid=gHh4q7I8dvWJzhdV
Hope this helps
Top ASUS Tablets & eReaders Experts
k24674
john h
Ngoro
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
