How to get wifi back on my 8 inch Nextbook tablet after switching carriers; new router was installed;entered the new password;the laptop works the tablet won't;disconnected then reconnected router.
If your WiFi is ON then the station ID should be showing when you look for a wifi signal with your tablet.
You should configure the Access Point with a new password and then attempt to log in with that new password.
You may need to uninstall the driver for the wifi on your tablet and re-install it using a new driver.
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
Hi there
You have checked that you are joined to the network via the router?
The laptop most certainly is.
Try disconnecting the router and turning the Nextbook off for a few seconds, connect the router on again and open Nextbook.
Join the network again and put the password in.
This way of connecting has worked for me. Hope it will for you.
