SOURCE: Toshiba printer e-studio 150
There is a small clear plastic circle under where the paper comes out, it has two positions, lock and unlock, sometimes when people grab the copies they bump it to lock, use a flash light and make sure its unlocked, you can also just remove it, it was there for shipping. L-codes = scanner lock problems, real cold conditions can cause the scanner greases to not allow the scanner to move fast enough, put the copier somewhere warm. Good Luck!!!
SOURCE: toshiba e studio 350
C970 indicates charging issue. Need to check the T/S block and main charger for deform/broken wires.
SOURCE: F103 ERROR CODE IN TOSHIBA E-STUDIO 282
F103 indicates HDD transfer time-out.
U can try format the HDD (08-690).
Then u perform the bad sector check (08-694). *take long time
If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
* replacement of HDD require firmware update
SOURCE: sir i have Toshiba e-studio 163 please tell me how
The toner detection is on the toner cartridge itself, where u can see the small PCB board. Try change another toner unit.
SOURCE: my toshiba e studio 350
the toshiba e350 needs a print dongle if the dongle is in
try this
1. turn on the power while 0 button and 8 button are pressed simultaneously
2. key in 947 and press the start button
3 press the initialize button
resart the machine
if it does not work then you can try updating the firmware and if that does not work then the card may be faulty
