We are working for Arris Router technical support benefit. We have more capable technical support group for arris switch or modem for the most part in USA and Canada. Our pros help you minimum complex arris switch modem about specific favorable position. Its elite depend on upon you and your issues, and we have to redesign at Arris Router client benefit number 1877-778-8@9@6@9 at whatever time 24x7 hours in a day. Click Here For Tech Support: https://goo.gl/ZZ6P8W
SOURCE: Arris Model: TM602G S/N: TM02AH1G6 Modem is not
Hi ltuttle650,
If your modem is not communicating with your Linksys router, your Arris modem was most likely installed directly to a PC or Mac when either you or a technician installed it. As soon as it connected it registered your MAC address from your NIC. You need to make your sure that the modem is still talking to the PC or Mac. Please try the steps below.
1. Find out what your NIC's MAC is (go to "Start", "run", "CMD", "ipconfig/all")
2. Copy down your NIC's "Physical Address." That is the MAC.
3. Go into your router's web based utility (Linksys is 192.168.1.1, username:none ; pw: admin) and click on the "Advanced" tab.
4. Then click on the "MAC Address Clone" tab.
5. Type in the number that you copied down. Click "Apply."
6. Now power cycle your Modem while it is disconnected from your computer and router. Power Cycle the router. After everything has rebooted connect the router to the modem and you should be good to go!
In most cases, this should work, and you ought to have internet access now.
If this did not work, the following is a quick fix:
1. Go to the 'Applications & Gaming' tab
2. Click the sub-heading 'DMZ'
3. Click 'Enable'.
4. Click 'Save settings'.
5. Wait for the settings to save, and click 'Continue'.
If this doesn't work, I would recommend calling your cable ISP and telling them that you need a modem that will work with more than one computer, or you need them to send a tech out who is able to set up the internet through a router.
Hope it helps.
Thank you for using FixYa.
Any type of technical issue can solve by taking a few minutes with our expert technicians who always ready for customer help. If the customer wants to get solution about all that problem, contact our Linksys Router Service Number +1-(833)-284-2444 for the USA which is totally toll-free number. There are available very expert technicians who will be helped you and provides your technical problem solving, and they also are connected online service between customer system, it service available for 24*7 hr. or customer can visit for more solution with our website.
https://servicenumber.org/
SOURCE: Belkin Router Tech Support pHoNe #{+l844^33O^*233O} nUmBeR UsA
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
SOURCE: Apple Router Tech Support pHoNe #{+l844^33O^*233O} nUmBeR UsA
SOURCE: Apple Router Customer Service pHoNe #{+l855^26O^*OO64} nUmBeR UsA
