Are you talking about different worksheets in the same file.
go to the other worksheet then go to the particular cell and press = on keyboard
then use mouse to select the other worksheet from the bottom of the spreadsheet .
Then click on the cell you wish to link and press enter key on keyboard.
https://support.office.com/en-us/article/Insert-or-delete-a-worksheet-19d3d21e-a3b3-4e13-a422-d1f43f1faaf2
https://www.microsoftpressstore.com/articles/article.aspx?p=2447199&seqNum=2
You can also do this to spreadsheets with different file names by opening both spread sheets in different windows and switching between the windows.
you can also copy just the data by copy whole sheet (click on the square in top left hand and copy and then right click paste special on new worksheet - with values only rather than the original formulas from the spreadsheet
Excel Workbook
.xlsx
The default Excel
file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets
(.xlm files in Excel 4.0).
Excel Macro-Enabled
Workbook
.xlsm
Uses the same basic
XML format as the Excel Workbook, but can store VBA macro code. Users saving
an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in
Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file
format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro
sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled
Template
.xltm
Can contain a
VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Workbooks created from this template inherit the VBAProject part or Excel 4.0
macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental
program that runs additional code. Excel add-ins use the Open XML file format
to store data, and they support using VBA projects and Excel 4.0 macro
sheets.
