[CE50] Temperature/humidity sensor abnormality
Is the connector CN317 on the LGC board or th
e connector of the temperature/humidity sen-
sor disconnected?
Is the harness between the LGC board and the temperature/humidity sensor disconnected?
YES
Connect the connector securely. Replace the harness.
NO
1) Replace the temperature/humidity sensor.
2) Replace the LGC board.
SOURCE: I have a copier, printer,
That is a auto toner sensor error code. Your machine most likely needs to be cleaned. That machine model will only cause you problems if all of the machine modifications are not done. You will need to take the left side cover off and completely clean inside the machine. Well worth the money to get a technician out to fix. Your machine will need to be re-calibrated.
SOURCE: place doc , feder in the down postion
Something is blocking the Original Present sensor in the document feeder. The machine thinks you are trying to use the doc. feeder to make a copy. Clear the obstruction and this should remedy situation.
SOURCE: toshiba e studio 450 fotokopi yazıcı özelliÄ?ini nasıl kullanılır?
If u are running networking for your E450, make sure that printer driver is installed on your PC. If using SMB printing, u can edit the driver properties.
The driver can be download at below site:
http://www.copiers.toshiba.com/support/swdrivers.shtml
SOURCE: How do you meter read Toshiba e-studio 453 copier?
"User functions"
"print total counter"
That's it......
SOURCE: toshiba e-studio 600 error ce50
Your copier has detected a temperature/humidity sensor abnormality. This sensor is located on the underside of your control panel. To reach it you will have to remove the entire control panel. Check if the connectors are connected firmly on both ends. If they are you might have to replace the temperature/humidity sensor.
Hi HABIB MILON, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
