SOURCE: Burned resistor in vertical yoke circuit. Pix displays vertical foldover
Part # 247674 2 Watt 220R
SOURCE: I have vertical shifted up from bottom and foldover from top down
This is caused by a defective capacitor in the vertical circuit. If you can solder, you should be able to fix this your self. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
SOURCE: LINE STAGE PC BOARD BURNT SANSUI SV29281
A good tech could probably fix that, did it burn a hole or otherwise carbonize the phenolic PC board material? If so replace the board.
You can only get that board directly from Sansui or one of their distributors. If your set is out of production (more than a couple of years old) there is a good chance that the board is no longer available likely get that board from Sansui, there will be no generic replacement for that. There is a safety factor involved here.
If you can get the board then replace it and see what happens. Hopefully it will happily give your more years of service.
