Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
S
Serge Esposito Posted on Jan 07, 2017
I have a mr.slim heat/cool model msz-ge15na.
Presently using for heating. I would like to know why sometimes I see only one operation indicator light lit, and some other times, both of them are (hard) lit.
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on Dec 29, 2010
SOURCE: mr. slim MSZ-GE15NA indoor unit
There is either a problem with the outdoor unit fan or compressor or there is a communication problem between the two....
Did you check the number of blinks and then check the book to see what it means??...
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
2answers
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Wall unit keeps frosting up, will not heat
Clogged air filter or a loose belt between the fan motor and fan wheel will cause a frost up.
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
1helpful
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
2helpful
2answers
Operating indicator light is flashing on Mr.Slim A/C
I had the same problem and I found it was that another unit had the heat running while I was trying to run AC on another (they're both attached to the same condenser) so it could only run heat or AC not both. Turn off the heat!
1helpful
Mr slim ductless ac choices
Try this Air Conditioner Sizing Worksheet from Consumer's Reports. It will help you.
I hope you find this information to be very helpful to you moving forward.
Please leave a rating. :-)
2helpful
Copper condendsing lines are cold but the air is not cold
http://www.mrslim.com/UploadedFiles/Resource/MSZ-A24NA_Op_Manu_SG79Y961H03_12-29-08.pdf Try this web site for you manual. It's where I found it.
Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
Top Mitsubishi Heating & Cooling Experts
 Mikey
Mikey
vince
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
