Question about Pride Health & Beauty
I'm working on a pride jet 3 ultra electric wheelchair. New batteries . Doesn't work, doesn't charge. When I plug it in the lights on the console flash. Unplugged there's nothing. Is this the charger
    Top Expert:
  • Pride Master
  • 85,206 Answers
Test the battery charger output voltage.
Posted on Jan 10, 2017
  • Pride Master
  • 5,907 Answers
If the batteries are new they will be virtually fully charged (check with meter) and if the wheelchair is ok everything should work so there is probably a fault in the wheelchair circuitry.
Unless the batteries are discharged it should not matter whether the charger works or not.
A multimeter is a great help when dealing with electrical and electronic equipment and a circuit diagram is almost essential except for the most basic of faults.
When checking the charger keep in mind it might be an intelligent charger and not produce an output unless it "sees" the battery.
6ya staff
SOURCE:
Why does the Victory 4 scooter not move. It worked fine for 20 minutes. I shut it off, then when I tried to ride again it would not go. No sounds. Battery is charged and light and horn works.
hi, there can be a number of reasons for this, from a controller fault to a weak pair of batteries to a brake that is breaking down..
Please contact me so i can advise further...
Regards
Rob
www.gewizrepairs.co.uk
Jul 06, 2014 | Pride Electric Wheelchair, Scooter, Power...
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Sunfire power chair won't charge but lights up when plugged in
you need to have the batteries tested it is possible that if left in a discharged state for an extended time that thee batteries may be damaged and will not be able to be recharged
May 24, 2010 | Pride Mobility Products New Pride Mobility...
Battery will not take a charge
Have the batteries load tested. If the batteries sat to long then they will not hold a charge.
Jun 08, 2009 | Pride Mobility Products New Pride Mobility...
The battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Batteries not charging - just replaced with new -amp meter dosent move while plugged in. Old batteries were dead and owners manual says charger will cease to work when batteries die and to contact pride...
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
May 07, 2009 | Jet 3 Ultra Power Chair
Health & Beauty Logo
148 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
