D
DERICK BESA Posted on Jan 10, 2017
KYOCERA FS 4200DN SHOWING MACHINE FAILURE CALL SERVICE 6120:0085277
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Jan 12, 2009
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Anonymous
  • 2120 Answers
  • Posted on Feb 10, 2009
SOURCE: CALL SERVICE 7410:0002988
Turn printer off
open left door
push in DRUM unit
turn back on.
Anonymous
  • 300 Answers
  • Posted on Apr 14, 2009
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
versa093
  • 46 Answers
  • Posted on Jun 12, 2009
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Anonymous
  • 622 Answers
  • Posted on Dec 24, 2009
SOURCE: What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Kyocera laser 4200dn was printing blank pages, then after doing drum refresh was ok for a while then started to print with missing or blank areas on page???
Ungortunately both drum and developer tank are suspects here. First stop is to remove drum so you can view the devloping magnetic roller to see if there is a thin even layer of toner on it. Because this is best done by a trained eye it may be best to get a Kyocera specialist company for an assessment. Try a developer refresh as well. See if that works. Good luck.
Kyocera FS-4200dn Fuser replacement
Search in Youtube..
It's Very easy to replace Fuser unit.
Just Observe the Fitting screws.
I am recieving machine failure on kyocera 4200 dn
The most common machine failure codes is CF---. For example CF248, CF000. In the most cases the printer is need to be upgraded to the latest firmware.
Kyocera FS-4200DN fuser
If the heat roller is dirty with "baked" toner, first you have to clean the roller with nitrocellulose thinner and immediately upgrade the printer to the latest firmware.
Repair kyocera fs-1028 mfp machine failure call service c7990
developer unit fitted correctly or failure of developer unit .
Machine showing machine failure call service
The waste box is integrated into the drum unit housing. DIRTY JOB without a toner vac. There are two ports (one one each side). The covers pry off. The service manual doesn't cover this because they want you to replace the drum.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
