Question about Sansui Televison & Video
Sansui rear projector sv4327i front lock pannel help me to onlock dont have the remote
5 Suggested Answers
6ya staff
SOURCE:
map9966
Mike Peluso
  • 2351 Answers
SOURCE: how to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Posted on Apr 25, 2008
francis rivero
  • 958 Answers
SOURCE: 2001 Hyundai Elantra door locking problem
there is a short or a signal from the un-locking switch that is triggering your locks.
you have a switch manually to lock and un-lock your doors, the unlocking circuit is making contact.
you can try playing with your switch to un-short the switch or open it up ang check it.
tnx 4 using fixya,
drcool
Posted on Sep 26, 2008
SOURCE: tv stuck on lock
my tv is not search the program and child lock the program plz to help
Posted on Feb 18, 2014
bigdawg7299
  • 2559 Answers
SOURCE: when press remote to open doors both front doors dont open only rear unlock and horn dont sound when set lock on doors lightsm jim to open door what could be the problem
Front lock motors - do they lock when you press lock? What kind of vehicle. Please repost with specifics.
Posted on Aug 19, 2016
Operation locked
you need a remote control to unlock the projector
the price of the remote control is USD30 (not including the freight)
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 14, 2014 | Epson EMP-1810 LCD Projector
I am bibin from kerala i have a sansui tv model sv/2110 now it remote is not working i brought a new one but it also not working. some of the channel are locked so i can watch 3 channels only how can i...
Hello Bibin
Have you teseted the remote handset for infrared radiation? You just check it first. You can check it easly, if you have a cellphone, which has camera option. Put the phone on camera mode, and place the remote handsets' front end towards it lens, at about 1 feet away or so, press each button. If there is infrared signal, you can see its image on the phones' screen. If it is there and still your set is not responding to the remote control, iinfrared sensor inside is faulty. You know that component. Replace it with same type and number. Without remote control, you can't access many of the parameters of your TV. Ok.
Dec 11, 2010 | Sansui H TV2600 TV
Sansui Home Theatre - rear speakers don't work
Select the Audio mode in Player remote control. On selecting the Audio mode 5.1, u will get all speakers to work. Cheers..
Sep 03, 2009 | Sansui VRDVD4000 DVD Player/VCR
Tv stuck on lock , model is SVLT150 SANSUI 15'' TV. I dont have the remote controller
Hi
Did you mean child lock? if childlock you need a remote control to open this tv..
Thanks!
Jul 08, 2009 | Sansui TVM1916 19" TV
HOW TO REMOVE PANEL LOCK ON A SANSUI LCD TV WITHOUT REMOTE
That tv usually has the customer service number printed on a sticker somewhere on the tv. Give them a call. They will help you for free. I hope this helps you.
Apr 24, 2009 | Sansui H TV2600 TV
Jensen JR400
Code For Model JER422
Code 3168 for Sansui DVD Code 3401 for Sansui DVD Code For Model JER422
Code 2010 for Sansui VCR Code 2031 for Sansui VCR Code 2111 for Sansui VCR Code 2123 for Sansui VCR Code 2130 for Sansui VCRif these dont work try
http://remotefinder.rca.com/
and if you cant find one there then your remote does not support this device.
Dec 24, 2007 | Jensen JER-422 Universal Remote Control
Home theater
The front pannel,on and off channels and vol. switches are going bad,if you dont use the front pannel, unplug the set and remove the back cover,just below the top screws you can look under and see the top of the picture tubes,in front of the middle tube is a little board about two inches wide and four inches long,unplug the right plug it has one black and five or so white wires,this is the top cable,then just use your remote.
Nov 20, 2006 | RCA P60920BL 60" Rear Projection...
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
