I have also tried using the cable box remotes and a universal remote from Best Buy. The problem persists. This makes me think the problem is in the tv. I am willing to replace part(s) for the tv. I just don't know what to purchase.
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.
SOURCE: Universal remote for Samsung Hitron
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
SOURCE: Samsung TV Remote
Replace it with a Universal Remote with Learning, This way, if the new Universal codes in its Manual don't work for your Samsung, (they most likely will if the new remote is not used older one bought off eBay) then you can Teach it to Learn codes off the working keys on you Samsung.
Sony Learning Remotes are a very good choice, sold at Walmart or eBay. The advantage to a good Universal, is you can also program in all your other audio/video remotes into one remote.
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
