Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.....
http://electro-medical.blogspot.com/
5 Digit Codes For Digital Converter Boxes
Access HD Digital Converter Code = 52185
Apex Digital Converter Code = 52478
CASTi Digital Converter Code = 52305
Channel Master Digital Converter Code = 52365
Daewoo Digital Converter Code = 52338
Daytek Digital Converter Code = 52305
Digital Stream Digital Converter Code = 52303
GE Digital Converter Code = 52360
Gridlink Digital Converter Code = 52348
Insignia Digital Converter Code = 51415
Lasonic Digital Converter Code = 52348
Magnavox Digital Converter Code = 51563
Philco Digital Converter Code = 51563
RCA Digital Converter Code = 52325
Sansonic Digital Converter Code = 52348
Sylvania Digital Converter Code = 51563
Tivax Digital Converter Code = 52185
Zenith Digital Converter Code = 51415
4 Digit Codes For Digital Converter Boxes
ACCESS HD Digital Converter Code = 1760
AIRLINK 101 Digital Converter Code = 1749
ALPHA Digital Converter Code = 1760
AMTC Digital Converter Code = 1760
APEX Digital Converter Code = 0519
ARTEC Digital Converter Code = 1759
CADENCE Digital Converter Code = 1758
CHANNEL MASTER Digital Converter Code = 1757
COSHIP Digital Converter Code = 1758
DIGITALSTREAM Digital Converter Code = 1751
DISH NETWORK Digital Converter Code = 0654
ECHOSTAR Digital Converter Code = 0654
GE Digital Converter Code = 1769
GOODMIND Digital Converter Code = 1769
GRIDLINK Digital Converter Code = 1746
iNet ACCESS Digital Converter Code = 1760
INSIGNIA Digital Converter Code = 1750
KINGBOX Digital Converter Code = 1759
LASONIC Digital Converter Code = 1746
MAGNAVOX Digital Converter Code = 0581
MICROGEM Digital Converter Code = 1747
PHILCO Digital Converter Code = 0581
RCA Digital Converter Code = 1032
SANSONIC Digital Converter Code = 1746
SKARDIN Digital Converter Code = 1749
SUNKEY Digital Converter Code = 1741
TIVAX Digital Converter Code = 1760
VENTURER Digital Converter Code = 1748
WINEGARD Digital Converter Code = 1748
ZENITH Digital Converter Code = 1750
ZENTECH Digital Converter Code = 1749
ZINWELL Digital Converter Code = 1740
Common 3 digit remote codes for digital converter boxes: 028, 029, 030, 031 032, 033, 034, 035, 036 and 037, 093, 132, 140, 149, 157, 161, 169, 174, 185, 186, 189, 198, 200, 207, 274.
Need help? Leave a comment below and we can assist.
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
