If you're having trouble scanning FM radio stations on your Pyle PBMSPG190, there are a few things you can try:
- Check your antenna: Make sure your FM antenna is properly connected to your radio and is positioned in a location with good reception. If your antenna is damaged, you may need to replace it. - Check the FM frequency range: Make sure that the FM frequency range of your radio is set correctly for your location. In some cases, FM frequencies may differ depending on your country or region. - Check for interference: Electronic devices such as smartphones, tablets, or other nearby radios may cause interference with your radio's ability to pick up FM stations. Try turning off nearby electronics or moving your radio to a different location to see if this improves reception. - Manually tune to specific frequencies: If the automatic scan is not working, try manually tuning your radio to specific FM frequencies to see if you can pick up any stations.
If none of these steps work, it's possible that there may be a problem with the radio's internal components. In that case, you may want to contact Pyle customer support for further assistance.
quisas alla sufrido un corto y se alla quemado tu estereo si es asi te compro la caratula y el control de tu estereo cuanto quieres por el mi correo es [email protected]
y la otra es que allas olvidado conectar el cable amarillo a la llave.
I ran across of alot of lcd head units that requiers the parking brake wire connected so it will show the video, (usually just audio if parking brake not on). But if you connect that wire to a proper ground (screen always on) or a grounded switch so you can control it maually (turn it on or off when you choose)
Hey honestly what you need to do is send the unit back to pyle and they will repair it. I have the same issue 2 times. What they say is the players power supply went out and that 80% of issues with the pyle products are improper installation. I am selling mine and you should do the same after you get the player back. I hope I could help
