Question about Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer
To resolve this error, you need to get support from technicians. Get support here: https://www.epsonsupports247.com/fix-epson-printer-in-error-state-issue/
Posted on Sep 19, 2019
Check our video out on a very similar model. Had error code that your printer is having:
Posted on Aug 20, 2019
Hello ,
This Error indicate that problem in your internal hardware. May be motherboard has been failure and other component is in bad condition.If you replace your motherboard with new one then your problem has been solve for permanently But you can solve your issues with the help of few steps.
Power off your printer and unplug all cables after 2 minutes plug all cables and on power.
This steps solved your epson printer error 0x97 problem.
https://www.phladvisor.com/question/epson-printer-error-0x97/
Posted on Nov 29, 2018
6 things to try
https://errorcodespro.com/epson-error-code-0x97/
6 Fixes For The Epson Error Code 0x97 Solutions The Error Code Pros
Posted on Aug 21, 2018
Hi alfred.
you could also try this link out you might find something at the link to help you out.
epson workforce wf 4630 printer error code 0x97 Google Search
Posted on Nov 07, 2017
SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Posted on Jul 07, 2009
SOURCE: Epson workforce 600 continue to
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
Posted on Dec 13, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
SOURCE: printer offline on wireless home network
first make sure the wirelss is enable and you are able to ping the print server .Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Feb 20, 2010
SOURCE: i have 2 epson workforce 1100
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Apr 05, 2010
Aug 12, 2018 | Epson Office Equipment & Supplies
Jun 05, 2018 | Epson Office Equipment & Supplies
Jul 06, 2017 | Epson Office Equipment & Supplies
Dec 08, 2016 | Epson WorkForce WF-4630 Wireless Color...
Nov 04, 2016 | Epson WorkForce WF-4630 Wireless Color...
Jul 05, 2016 | Epson WorkForce WF-7620 Wireless Color...
Jun 20, 2016 | Epson WorkForce WF-4630 Wireless Color...
Jul 03, 2015 | Epson WorkForce WF-3640 Wireless Color...
Mar 27, 2015 | Epson WorkForce WF-4630 Wireless Color...
667 people viewed this question
Stay away from Epson! do not by any Epson product the company is one giant ***** and their products are just a scam so they can sell you overpriced ink!
I'm on my 5th Epson WTF 7620 Warranty replacement printer in three years (!!!!) with the notorious error code 0X97 that just died on me Today Nov 7 2017 !!!!!!!!!!!!!!
Hello ,
No need to panic. Epson printers are just very sensitive when inks are not Epson brand and if there is a piece of paper or something that gets in the printer.
