Question about Amazon Kindle
I am unable to use my Kindle Fire 2 on the battery, only when plugged into the electricity. Please call me at 617-365-6722.
Unable to start (turn on) Kindle Fire 8.9 HD
Try plugging in charging cord and see if device powers on while connected to mains power if so and it doesn't start off mains it's your battery. If it doesn't turn on with regular charger try another charger with same connector to be sure it is not your charger that is faulty. Failing all of this, and you are handy, you can search for battery part number on net buy one from China and install yourself. PLEASE ONLY IF YOU ARE COMPETENT DO YOU TRY FIXING ELECTRICAL PARTS YOURSELF. Alternatively it is probably easier to buy a new ereader.
Nov 07, 2016 | Amazon Kindle Fire HD 8.9"
Text to talk active. need to turn it off, but tapping on top bar has no effect. Unable to get to accessibility. help
Amazon.com: Customer Discussions: Kindle Touch- text to speech not ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jan 14, 2012 - Has anyone had a problem with the text to speech option not working? It had been ... Press "Menu" button again 6. Touch .... Is it possible to enable text-to-speech in kindle fire? I see the .... Introducing the All-New Fire HD: Powerful Tablets Designed for Entertainment, 0, Sep 18, 2015 ... Most active community forums ... kindle fire hd 7" , touch screen problem
May 16, 2013
Kindle Fire HD text to speech
Apr 10, 2013
Does Kindle Fire HD have text to ...
Mar 19, 2013
Kindle Fire Keyboard Not Working
Sep 22, 2012
More results from www.amazon.com
Turn Off Kindle Fire Accessibility - Love My Fire
Dec 25, 2015 | Amazon Kindle Fire HD
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
How do I see if the recharger cord is working? Kindle fire did not recharge overnight.
Three possibilities. 1. Battery is defective. 2. Charger is faulty. 3. Tablet's 5V socket is broken or loose.
Jan 21, 2015 | Tablets & eReaders
Kindle will not turn on
The Kindle Fire will not turn on, correct? Let's try a hard reset.
Step 1: Unplug the device from the charger
Step 2: Press and hold the power button for 30 seconds
Step 3: Release the power button, then press and release the power button normally, the Kindle should wake up
Step 4: If the Kindle does not wake up, find an alternate charger or go down to Radio Shack or Staples and get a new charger
Step 5: Plug in the new Charger to the Kindle for 12 hours when done leave the Kindle plugged into the charger
Step 6: While the Kindle is plugged into the charger, press and hold the power button for 30 seconds. Let the Kindle charge for another hour.
Step 7: Pickup the Kindle, press and release the power button normally, the Kindle should now wake up.
Step 8: If the Kindle does not respond, contact Amazon for a replacememnt
Apr 21, 2013 | Amazon Kindle Fire HD
Kindle fire unable to connect to any routers since traveling by plane. its not on airplane mode
The Kindle uses a standard 802.11b/g/n card, so the format is universal. Maybe the WiFi card is turned off? Remember, you have to make sure the Kindle is out of Airplane Mode AND the WiFi Card needs to be ON. If you can not connect to a major carrier at Starbuks, Peet's Coffee or any major coffee house then the issue has to be sometime on the Kindle is OFF. Did you install a battery saving package that may be intercepting the wireless connection? Just a few ideas.
Mar 28, 2013 | Amazon Kindle Fire HD
Kindle keeps turning itself off
This is usually a sign of either a failing charger or Kindle, let's try to hard reset the Kindle.
Step 1: Press and hold the power button for 60 seconds
Step 2: Plug the Kindle into the changer, press and hold the power for 30 seconds
Step 3: Let charge for 12 hours
Step 4: Turn on and use the Kindle, if it shuts down before 6 to 8 hours of use, contact Amazon for a replacement.
Mar 26, 2013 | Amazon Kindle Fire HD
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
Kindle fire won't charge
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't charge this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
Sep 24, 2012 | Amazon Kindle Fire HD
Amazon Kindle Logo
Top Amazon Tablets & eReaders Experts
Peter Dragonetti
Sheldon Dedek
gggg
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
