If it's your device and you just forgot the password, you can still reset your device through iTunes or iCloud. Follow one of the methods shown below.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more details, check: How to Reset Password on iPhone
In iOS10 how to use easy way to unlock the screen
If you want to use the slide way back to unlock iPhone screen, here's the steps for you to follow.
You should check if your device meets the condition. That is, your iOS device must have Touch ID-enabled feature. Including iPhone 5S, iPad Air 2, iPad Pro, iPad Mini 3 or other later devices.
Hi juanita , I want to help you with your question, but I need more information from you. Please call customer servicefor Help and Support 1 8O5*465*751O Toll Free 24x7
